About modifying the fade time of each cue in the cuelist
  • Hi and welcome in our forum :)
    So when I stop and start again, the changed fade time is applied only then, is this normal?
    Yes, this is totally normal and the way DMXControl 3 works. Fade / delay times are only updated after restarting the cuelist and e.g. fannings on device groups are recalculated for group size changes only after reapplying the fanning (or rerun the cuelist in which the fanning is stored). Otherwise, those checks would have major performance impacts and thus are not done.
  • Later cues in a cuelist depend on earlier cues. So lets make an example: If the first cue sets the dimmer to 100% and the second cue sets the color to orange, then 100% and orange is output if you run the second cue because the values of the first cue also count. This is the reason why the playstate of the cue changes if you activate it (because all later cues depend on it).
  • Oh, I think you're referring to the concept of tracking.
    I turned on Acive after turning it off
    The change in the fade time of cue was applied right away without STOP cuelist and GO again.
    I came across it by chance, but I was wondering if I could change the fade time like this
