Hello,
using Sound analyzer we can set the Bank as manually so as from a command, however child features like "raise spectrum, treshold and set to 255..." we can set only manually. There is no ability to change that value from commandbox using command line or something else.
Let me give an example. Using RGB LED (4x6) devices Sound analyser manages all 24 its channels, all check box (raise spectrum to, treshold, set to 255...) are marked (digital output) . Everything is OK. Now lets use the exact devices for strobing. The first DMX input of the RGB LED device enables as follows
ch1
Strobe
0-29 = Dimmer
30-244= Strobe (0,5Hz - 30Hz)
245-255= SYNC
to use Sound analyser outputs to manage strobo speed. The problem is I change the Bank using chaser/cue/command box, but I should unmark manually "set to 255..." check box to change output from digital to analog as only in this way the RGB LED device works properly. That way takes time and isn`t convenient.
Another example: mark on check box "All equal/VU-Meter" changes way the same RGB LED and Blinder devices act.
Questions: is there any other way or solution to manage Sound analyzer chech boxes? If no, is it possible/difficult update DMXC that changing Bank it affects on mark of check box too (every Bank has its own check boxes values).
Regards,
Darius
PS. The devices I`m using is home made 8x30W RGB LED and 8x50W LED Blinder by http://www.hoelscher-hi.de/hendrik/english/led.htm information.
