Hello,I installed DMX Control last year and had good results but since then I haven't used it.I have come back to it and can't even get started none of my previous files seem to open,when I click graphical view nothing happens.I have installed the newest version,I have tried creating a new file with the same results,can I have a little help to get started please then I will figure the rest out
Getting started
- fincaman
- Thread is marked as Resolved.
Hi,
basically, DMXControl 2.9 and 2.10 are compatibel. It shoudn't be a problem to open an old project. Nobody else reported such an problem, therefore I assume there is another kind of error.
What do you mean with "creating a new file" and same results?
An DMXControl project file has the extension .stg
Did you really try to open such a file again after saving the project?Regards Frank
My problem is more serious than I thought I have uninstalled reinstalled an reebooted and now I get an error message when I try to start DMXcontrol it reads
380 invalid property value
frm buttons
idmxc tool viewmode let
50090the palet that pops up has several buttons in German if I click one of them the programme loads but I get the same results as before i.e. graphical view won't open
I installed the previous version on my laptop last year and have tried it
and it works great so the programme is not installing properly on my desktop can you help? -
Any chance of any help with this ?
Did you have a secondary display the last time you used DMXC?
This sounds a little bit like the windows are on the wrong (secondary) screen or get a wrong size.
If you have DMXControl 2.10 installed, try the menu entry "Windows -> Move all windows to primary screen".Regards,
Stefan -
I have a 32" main monitor and a 20" Seconary display ther is no difference which ever one I put it on
It seems my problem is insurmountable,the evidence points to my computer but I run some heavyweight programmes (Cubase ect) and they all run fine.I would have liked to have seen a little more interest especially from the administrators.
Well guess what ? I have just tried DMXC and it works fine,it's cured itself weird !!!
Souko
Moved the thread from forum Technical issues [v2] to forum Help and Support [v2]. -
