Hi all
I am currently having issues with getting the audioplayer in DMXC to see the waveform from winamp. So if any one can give me any inspiration on why this is not working your thoughts will be very welcome!
Many Thanks
Bryn
Hi all
Many Thanks
Bryn
Hello,
I'm sorry, the synchronisation between Audioplayer and Winamp is only described in the German Wiki:
http://www.dmxcontrol.de/wiki/Audioplayer
The important point is, that the mp3-ID3 Tag has to be identical to the Audiotrack name.
X indicates succesfull matching, "-" non successful.
Good luck
Frank
Hi!
And as far as I remember, the waveform is not visible if the audioplayer is controlled by winamp!
You have to "design" your show first with the inline player and can run it afterwards with the winamp-controller.
Hoc
