variable for trigger value
  • Hi all,
    I'm experimenting with the duration of my cues where all of my cues are of the same duration. Is there a way to use a variable for the trigger value so that I can change the value of the variable and have it apply to all the cues?
    Thanks,
    Charlie
  • JPK
    Approved the thread.
  • Hi and welcome in our forum,
    there is not a direct way to set a master (our DMXControl wide kind of variable) as the entry of a trigger value. But the question is, what is your purpose? Maybe, there is another way to get the intended result.
