Hello,
I updated to 3.2.1 from 3.2.0 recently. But now everything seems to be bigger. Is there any way to change size of icons and text?
thank you for helping me!
Hello,
Hello!
What is your default scaling of Windows in the settings for your desktop resolution?
Might it be that you have a 4k Monitor?
Firstly thank you all for quick respond. I have 1920 x 1080 full HD screen and scaling set on 150%. I can set it on 100% and app looks exactly as i want it to, but it makes everything else smaller.
Well, the point is, we fixed a Bug. In the Past, DMXControl was not considering the Scaling, which lead to others reporting: "I scaled my screen to 150%, but DMXControl is still small". So we fixed that bug to have DMXControl (as every other Software) considering the scaling. That's the reason why it looks different now.
So I can't change it somewhere in config?
Unfortunatelly not, this is an application Setting, on a Operation System Level.
But you can change it differently. Try this out:
1. Goto here: https://pocketnow.com/hidpi-scalling-in-windows-10
2. Follow the Steps described in "Edit the Registry".
3. Copy the attached Manifest File into the LumosGUI Installation Folder, so it is parallel to the LumosGUI.exe File (Unzip the ZIP)
4. Never ever report any Bug regading miss-scaled Controls, Visual Glitches or other things concerning the UI displaying Stuff in a strange way. By using this configuration, you are using DMXControl in a visually untested environment and support ends here.
Regards,
Arne
I didn't want to scare you, if you prefer, you can definitely try it out. With my last sentence I just wanted to make clear that this is not supported by us officially. In case glitches occur, we will not start fixing things, as in our opinion, this is not a bug right now. It's just that you want everything @ 150% besides DMXControl, which is an unusual request.
