Enttec DMX USB Pro Mk2 - doesn't seem to be working with DMX Control 3?
  • Hi,
    Has anybody managed to get DMX Control 3 working with the Enttec DMX USB Pro Mk.2 interface?
    It's appearing in the interface list, but isn't outputting any DMX (the status LED on the inferface remains flashing white, meaning the interface is idle - it should turn green when DMX is being transmitted)
    I've tested the interface with Enttec's own D-Pro software, and it works ok, so I don't think the interface is faulty.
    Does anybody have any ideas what could be preventing this from working?
    I've attached a screenshot of the output/interface/monitor in DMX Control 3.
    Any help would be much appreciated!
    Cheers,
    Phil
  • Has anybody managed to get DMX Control 3 working with the Enttec DMX USB Pro Mk.2 interface?
    I can see you have configured the interface as an "Open DMX" interface, which is wrong. However, DMXC 3.2.1 does currently not fully support the "Mk 2" version, this will only come with the next release. But as the "Mk 2" is backwards compatible to the "Pro", you can still use it, but with just one universe working.
    The interface should be detected under the "Enttec" category, but not under the one under "Non auto detect interfaces" (as the Pro can be autodetected).
    Stefan
  • Post by Davide Sarto ().
    This post was deleted by the author themselves: I wrote in a thread marked as solved so nobody answer ().
