Hi,
I'm trying to do a very simple thing - press the GO button by means of a MIDI message. I've chosen Note On (C1) with a velocity of 127 for this. And I've had partial success...but still there's a snag.
So I've:
Used the MIDI Manager to create a rule (button) that responds to the correct message.
Used the Input Assignment page to link my rule to the GO button.
Doing this I found that I had to set the 'Is Toggle' option in the rule to Yes otherwise it wouldn't work.
I now find that I have to send two Note On messages because the the first one 'latches' the binary switcher (that was automatically created in the Input Graph) to a 'True' output. It presses the GO button as required but doesn't afterwards reset the input state. I have to send a second MIDI Note On to do so. As I want to program these control messages into another piece of software this is a bit worrying as, if it gets out of step, chaos will ensue!
I'm obviously missing something. So my question is very simply: what's the best way of setting it up so that each time I send a Note On (or it could be any other message), the GO button is pressed?
Thanks in advance!
