i'm using DMXControl 2 software with the k8062 velleman interface. I'm testing the setup with some led pars. The issue is that when i try to gradually increase/decrease the brightness of the fixtures it doesn't work linearly. It seems like the brightness increases in steps and it's easiy noticeable that is not a smooth transition. I've also tried the channel view to increase manually the dimmer channel.
Can it be fixed or at least improved by software? I know that unfortunatelly the velleman interfece is kinda slow.
DMXControl 3 may improve the situation?
Thanks.
