Hi all. I'm using version 3.2 and I have created several cues. While playing back a cue I noticed I needed to make a change. So I right click on the cue and select "Edit in Programmer". When I do this all the lights go dim at 15% for some odd reason. This is NOT how the cue is recorded and it is NOT how the cue is played back. What is being sent out to DMX is nothing like what is programmed in the actual cue. In fact, when I view a device in the "Device control" window (while in edit mode), it shows the lights at 75% which is exactly how it is programmed. BUT the DMX signal being sent out to the actual lights is at 15% (should be 75%) and the graphical display in the "Stage View" also shows the lights at 15%. But the actual device in "Device control" says 75% which is also very odd. Something is goofy here I believe.
What I expected was the DMX out to be what is programmed in the cue so I can actually edit the cue. Right now it is impossible to edit a cue. I tried editing in Blind and I've tried all kinds of cuelist configurations. The Stage View doesn't help because it displays what I see (which is NOT what is programmed in the cue). I don't know if this is a bug or that I'm missing something. There are a few other goofy things I've noticed, but this is by far the biggest issue. Not being able to edit a cue makes this impossible for me to use at this time.
Any help with this would be appreciated.
Rico
