yes test with the File i uploaded before
Stream Deck- Setting up and using with input assignment
All working, and all of the buttons are now displayed on the stream deck.
You are a legend!
Animation works correct?
15 Buttons shows up in DMXC? -
Oh you was faster
Can you test the Buttons-Press working
Brightnes set working?
Yes, animation correct and all buttons displayed 1.1, 1.2 etc. I'll get to test everything properly tomorrow!
NO - I added a button to the tree, and pressing the button doesn't update the button from false to true.
I created a slider in softdesk and attached to the brightness control. It works
The buttons are now working. I just needed to connect them to something.
Have FUN!^^
Thanks a million for all of your help. Can I send you some beer tokens or something?
Sweets are always welcome^^
Thanks again for all your help the other day, and I've started programming up some of the buttons.
I've just loaded up DMX Control with the Stream Deck plugged in. The animation appeared on the stream deck, but was a bit distorted, and then DMX Control froze.
I tried loading it up again with the stream deck unplugged, plugged it in, and then loaded up my project. The animation displayed as before ( distorted ), and DMX froze while loading my project.
I'll see if I can get it loaded up, and send you through a log file if you would like to take a look.
Had to go into task manager and manually kill the kernel, then DMX restarted. (Stream deck is now working).
Hi all.
Not sure if I should start this on a new thread - let me know.
I have spent a while setting up my stream deck buttons. It's not perfect, but working. Sometimes when you start DMX control, some of the buttons are distorted. If this happens, you have to shut down DMX control and reopen. Sometimes it will fix the problem, other times you'll have to restart the program again.
Dmx control will also not remember my DMX interface (Enttec open DMX). Each time I start DMX Control, I have to delete the interface, and add it again for it to work.
BUT, here's my main problem. Any of my lighting fixtures that I have programmed in that use a dimmer, shutter, and one with rgb values - to work - are not working.
When I change values on the light fixture, it's not changing the values on the dmx output. If I use the channel overview, I can manually change the values to light up the fixture.
I've a big event coming up tonight, and need to get to the bottom of this. Everything was working perfect until I reinstalled DMX Control 3.2, and added the stream deck.
I have also tried replacing the DDF for the light fixture in the saved zip file.
Is there a setting that could be affecting this, or has a problem happened that has affected all my lights DDF files?
I have attached a log file and included the DDFs for the lights that I am using in this setup.
Light cue's sorted. For some reason the Grandmaster had set to 0. Don't know why, as nothing is linked to it. Problem sorted though
