We now have a MacroBoard on the input assignment!!! There is no serial number listed, and no animation on the stream deck, but the buttons are listed if you open the SN.
Stream Deck- Setting up and using with input assignment
logfiles please
Logs.
I put the hid.sharp.dll file in the test folder, and it is now doing the following:
I Thint these are old Logs,
Can you please close the complet software, check it in the Taskmanager (Lumos, LumosGUI)
Be sure teh GUI and KernelFolder hase both Dlls i Uploaded
Start the Software
Export the Logfiles
I restarted the pc to make sure.
OK, try the testtool
Ar the Buttons working?
Copy the dump here -
It just opens with a blank screen.
Now?
Nothing happens when you press a key
Now?
Yes !!! When I press keys on the stream deck, they light up random colours
ok, Copy the StreamDeckSharp-File from the test in kernel and GUI and try
I had tho fix one thing, so you hhave to Change the dll again
An animation is now playing, and a SN is now displaying on the input assignment.
Don't think it correct though, I'm uploading a video of the annimation
Is the Animation to Big?
It's distorted. The first video file was too big. Uploading another.
Test this
Video of stream deck connecting
PERFECT !!
