Hi, I'm moving over from a Midi desk (APC Mini) to a Stream Deck (15 key) to control my lighting.
I've installed the stream deck application (and closed it on my windows 10 machine), but still can't see any instance of it here on the input assignment. From what I understand in one of the 'did you know' guides, that the stream deck will be accessed via it's serial number on the input assignment (so you can run more than one).
Do I need to do anything within DMX Control 3.2 to activate the stream deck and make it visible?
The stream deck is working properly. When I plug it in, it lights up with the stream deck logo, and when I launch the stream deck application, the middle button shows welcome. I just can't see it within DMX control (I've restarted windows and DMX Control since).
Thanks all
