For some reason short single commands are intermittantly missed by the entec open usb widget. At first I thought it was a midi problem when using a sequencer to control lights with key on/velocity commands. Using the scene list, the changes are also missed intermittantly if there is no fade in time set. If there is a fade in time set on the scene it works correctly every time. This fadein would of course cause multiple commands to be sent so if a few were missing they would not be noticed. Is this a device polling or buffer issue in the output module? Im using hippy's output module obviously. I know it is not an issue with entecs driver as the problem doesnt show up when i use another application to send midi commands converted to dmx to the interface. Love the program, but intermittant doesnt cut it.. Any thoughts/help??
Thanks!
John USA
