Dimmer irresponsible
  • Hello.
    My custom built Nodle U1 device is working in our home theater, where we use some generic dimmer rack. But when I try to use this dimmer device, it is unresponsible. The dimmer is working with any other dmx console, but not with Nodle. When I connect the dmx cable from nodle to dimmer it says "Dmx received" on the LCD, but then nothing happens and I can't control it. I can't find any data if this dimmer uses any special DMX signal or anything specific. Nodle definetly works, but it is strange that it doesn't work on this dimmer. Does anyone have any idea, what could be wrong?
    PS.: I am using QLC+ software if it's of any help..
  • Hi,
    this maybe comes from the absolute correct DMX signal of the nodle. Some DMX devices doesn't support that, because the manufacturer use cheap components. To solve this problem, you can change the dmx signal parameters in the nodle (thats the reason, why we add such a function). Just change the break time a little bit (about 5 - 10 digits) and try it again. If this doesn't help, do another change till you came to a change of about 50 or 60 digits. Then start to change the mark time too. Beware, the smaler the change is, the better is the refresh rate of the DMX signal. So it is important to do as few changes as posible.
    Regards
  • This configuration can be done in the interface settings. I don't know, how this works in QLC+ but there should be a configuration dialog for the interface. If not, you can use the configuration tool in the project achive of the nodle. With it, you can not configure every parameter, but there is a "fast" and a "save"-configuration (you find it under "parameter")
