Hello.
I recenty built my own version of smd pcb for nodle1 with small modifications. Now, I just have to program the atmega32u4. But I can't find any information about fuse bits. Can someone please tell me which fuses must be writen?
Thank you.
Atmega fuses
- bmandl
- Thread is marked as Resolved.
None because we use the internal bootloader!
Thank you for reply. I already finished the project. My atmega arrived empty and I had to upload a bootloader on it with a programmer.
Sent from my iPhone using Tapatalk
Hi,
there's already a bootloader on the ATMega32U4 !
If you pull down Pin HWB and performing a Reset, the ATMega will start it's internal DFU-Bootlader.
Then you can Upload the .hex-File by Using Atmels FLIP!-Tool via USB. -
Hi,
Then you can Upload the .hex-File by Using Atmels FLIP!-Tool via USB.Atmega was empty. I bought it on ebay
Hm, thats strange !
If the ATMega32U4 was a new one, there must be a DFU-Bootloader which you can program with Atmels Flip-Tool via USB.
This is so specified by Atmel and is also sold by Atmel.Maybe you got a "China"-One ?
Or you haven't installed the DFU-Drivers before you tried to program with FLIP. -
If you buy an Arduino Uno clone from China, the serial interface chips are not what you might expect. The serial interface is a CH340 UART and it requires a different driver than the one supplied with either the Arduino or ATMEL software.
rieka, we don't talk about Arduino ! We talk about the bare Microcontroller - these are directly shipped from Atmel with preloaded DFU-Bootloader. There's no Serial to USB Chip or similar.
Hm, thats strange !
Or you haven't installed the DFU-Drivers before you tried to program with FLIP.Yeah, it was "China"-One. Maybe it wasn't new at all. It was definetly empty, I checked it with ISP programmer. Anyway, I loaded bootloader with my ISP programmer and then programmed it with FLIP. So, no harm at all
