HI:
I have tried many times to use Sound2Light without success. I can´t achieve to receive signal from winamp.
I´m probably missing some basic step. Can anyone tell me step by step what I need to do to use this tool.
I have the dmx 2.12 version and winamp v5.666
Thanks
try this
https://www.dmxcontrol.de/wiki/BeatTool_DMXC2
http://www.dmxcontrol.org/wiki…l_DMXC2#Winamp_AVS_pluginor
http://www.dmxcontrol.de/wiki/BeatDetection_Plugin_DMXC2
download the plugin and copy "BeatDetection.dll" in the plugin-folder from dmxcontrolenable "experimental tools" under settings and the plugin
Hi Lichtfuzzi:
Thanks for your help.
I followed the instructions. I was able to get the sound2light to work only with the BPM Studio. I supposed there is no difference with the WinAmp AVS Plugin, but this one I could never make it to work.
Also I can´t make the beat tool work.In the Beat tool, the brown box stays brown and the number below stays in 0.
The number under the tab button change.
And the BPM: stays in 0.
Can you give me a clue of what I´m doing wrong?I installed the BPM-Studio Plugin in dmxcontrol plugin folder.
I installed the AVS-Plugin in the winamp Plugin folder.
I installed the Beat Detection Plugin in DmX Control and check to select it in plugins.
I set in winamp, plugins visualization: one of the Plugins (BPM)
I set in Dmx Control, Program Settings, Tools (VBVis-Plugin).Thank you
Sebastian
hi,
for the avs-plugin you have to select avs-plugin in the programm settings
the beatdetection is for line-in (mic-in or sound-interface)
i use the vbvis-plug in.
select this plugin in the programm settings.
download the .rar in the link below
Analyser-Ansteuerung
and copy the gjvis10.dll in the winamp-plugin-folderyou dont neet to select the plugin in winamp. i use the milkdrop-visual-plugin and beattool automatically works great with that combination
sorry for my english, its bad, and in the morning worst
Hi Lichtfuzzi:
Thank you again for your help!
I couldn´t make the avs to work. But the vbis plugin now works great, and that´s all that I need!
I can´t say that your english is bad. I´m sure that is better than mine and definitively better than my german! I´m from Argentina!
Vielen dankSebastian
Souko
Moved the thread from forum Feedback und features [v2] to forum Praise and Criticism [v2]. -
Souko
Moved the thread from forum Praise and Criticism [v2] to forum Development and Features [v2]. -
