Hi, i was hoping that someone might be able to help me get beamer (BeamerTool.zip) working. I didn't know that i was using DMXC version 2.11 on my laptop, so uninstalled and installed 2.12.2. That caused a few problems, spent half the night working through those. I thought it probably was because i was using an old version. No difference though, i still get the same error. There are no instructions that i can understand except from what i got, you just copy Beamer.out.dll to the plugins folder, is that right? I also tried copying the entire folder tree from that file, same results with other errors as well.
So with just the dll, i launch dmxc, and get:
The plugin 'Beamer.out.dll' does not implement class IDMXCPlugin correctly. The plugin is not compatible with this verion of dmxcontrol. Error 13: type mismatch
I am using beamertool from this link:
http://www.dmxcontrol.org/downloads/file/3-beamertool.html
Has anyone else had this problem.
I can't end a message without saying what a fantastic program DMXC is. I haven't had a chance to start with version 3 yet, but it looks pretty top notch as well.
Thanks!
Rob T.
